Old 6th March 2013, 04:18 PM
jps jps is offline
Originally Posted by loony View Post
Bearing rotate in the mount until you tighten nuts - then it's quite solid mounted but at the angle.
I wonder how it will work with adjustable column, but should be ok - it doesn't need too much move...
Sounds great - not sure all of them work like that - where did you get it from?! Is it available in UK as easily as Poland?
Old 6th March 2013, 04:42 PM
will_08 will_08 is offline
This is pretty much what everyone else has used from what i can gather
SLFL25 LDK Pressed Steel Flange Bearing
http://www.ebay.co.uk/itm/SLFL-SBPFL...em2 eb52066ff
£6 odd delivered
Old 6th March 2013, 07:14 PM
jps jps is offline
£6 odd delivered
That one doesn't look like it can be angled in the mount though...?
Old 6th March 2013, 07:36 PM
I'm pretty sure it does, ill take mine out the bag and check later.
Like i said tonnes of peeps have spec'd that bearing for this job
Old 6th March 2013, 09:02 PM
loony's Avatar
loony loony is offline
Yes - "SLFL25 LDK Pressed Steel Flange Bearing" it's the same type of bearing. There are minor differences in insert bearings, but they are not important (like tube length etc.)
But - it wasn't so easily available in Poland - especially housing isn't popular. Everyone (except me) prefer cast iron housing for agricultural equipement...
But I wanted "lightweight" version So for my special order... I got it.
Lucas
ZX9R BEC Haynes Roadster - build cost so far: £1125
My build thread
"Whatever you can do or dream you can, begin it. Boldness has genius, power, and magic in it." J.W.Goethe
Old 8th March 2013, 12:52 PM
I can confirm this one can be angled, just recieved my one from that listing.
Old 8th March 2013, 08:22 PM
jps jps is offline
And i've just had one of these http://www.ebay.co.uk/itm/2006116904... 4.m1439.l2649
drop through the door today. Which also pivots. :-D
Old 8th March 2013, 08:45 PM
Aint we a pair.
Although I can also confirm that the 25mm one doesn't fit the MX5 column... :doh: I would know that if I had read the Saturn guide properly that says to buy the 205-14 (7/8") one, or even measured my column.
Luckily I have some 1" bar stock that I can make a bush out of.
Old 9th March 2013, 02:27 PM
loony's Avatar
Looks like we have to specify what donor running gear parts fit
So... to make it clear - mentioned earlier bearing fits Sierra steering column (with little bush turning or without modification).
Lucas
My build thread
Old 6th August 2013, 06:49 PM
Josh's Avatar
Josh Josh is offline
Bumping this to the top rather than start a new thread.
I'm using a standard Sierra rubber bush to support my steering column - will this be good enough for IVA man?
I have also replaced the (worn) nylon collar that fits into the rubber bush, however it is a bit slack. Was thinking of turning up a PTFE collar with a retaining lip to take up the slack - again, ok for IVA man?
