Old 25th July 2013, 07:32 PM
Default Seatbelt extension?
My seatbelt saga continues. I have some proper 7 style TRS belts now but with the seats I have the lap adjuster is nearly impossible to use.
Because the lower part of the seat belt is so short, the adjuster buckle that you need to peel back to allow adjustment is trapped between the seat side and the side of the car.
One option is to cut out the seat belt mounts and weld them in higher/further along. This option isn't great because I have bonded the trans tunnel sides on now and the chassis is painted.
Another option would be to make up some extenders with some 3-5mm plate and bolt these in between the seat belt anchor point and the seat belt mounting hole which would give me the extra length I need.
I think this would work fine and be as safe as bolting directly to the chassis but dont know how the IVA would look at it.
Final option is to get custom made seat belts, or have these ones professionally altered so I can specify this length.
Any opinions out there?
Old 25th July 2013, 08:15 PM
PorkChop PorkChop is offline
The ones Johno got from Prima Motorsport look really nicely made and FIA approved too.
Old 25th July 2013, 08:27 PM
They are cool but twice the cost of these ones and its only going to be a road car so I didnt want to spend that much on harnesses. I will If I have to but...
They have these things on ebay,
Those wont be e marked but they work on the principal of my metal straps so I hope it might be a good solution.
Old 25th July 2013, 09:02 PM
Can you not just make a taller mount? You will have to change you side panel but at least you should have no iva worries. I am going for the same straps as johnno as the trs ones were difficult to adjust. The lap belt kept riding up to my chest on both the saturn demo car and also a caterham I got for the day ( after I kicked off to ansar ali about his sales manager who didn't take me seriously although I wanted one - money well saved!)
Old 25th July 2013, 09:42 PM
Won't the buckle/adjuster end up in the same place? If you move it forward, the belt is looser and needs tightening up more, thus putting the buckle/adjuster in the same place?
Old 25th July 2013, 09:52 PM
The adjuster buckle is the fixed point, between the adjuster and the lap buckle gets shorter.
For the sake of making a couple of metal straps Ill probably try it to see how it goes but I feel I will end up selling these ones and get some of the Prima ones made to my spec in the end.
