Old 28th September 2014, 12:05 AM
raceral raceral is offline
Do you have a residual valve? If your master cylinder is located lower than the wheel cylinders or caliper it is recommended to have a residual valve in the line.
Al
1969 Amx
2004 Passat 1.8T 5Spd 4Motion
Haynes Modified Super 7 3.4L V6
www.lotussuper7replica.com/
Old 30th September 2014, 03:24 PM
All fixed now. The rod between the pedal and the cylinder was pushing the brakes on a little all the time. I've adjusted it and also taken it for a nice long run around the twisties! It's a bit rapid!
Old 30th September 2014, 05:41 PM
Glad you got it sorted, and great to see you you've finally got it on the road!
They are a bit nippy aren't they! Mine still makes me grin every time I drive it
Old 30th September 2014, 06:50 PM
Once it goes past 4000 rpm it takes off!
When I figure how to edit go pro movies I will upload some.
Old 1st October 2014, 08:08 PM
Is yours a 1.6 or 1.8 David? Making me jealous with all this fun talk!
Old 1st October 2014, 08:34 PM
Apparently, there's not much difference between 1.6 and 1.8. I've heard of MX-5 fans going to great pains and expence to get a 1.8. When they succeed, get disappointed with the amount of pull anyway.
Old 1st October 2014, 08:59 PM
PorkChop PorkChop is offline
There isn't really IMO (if you're comparing an early 1.6, post '94 Euro market cars are a slightly different story), the benefits of the 1.8 over the early 1.6 come with the stronger diff, better brakes and more bracing as standard.
Old 2nd October 2014, 02:31 PM
its a 1.6 Chris. I was worried it wouldn't be powerful enough but its plenty for now!!!!
