Old 10th December 2016, 10:03 PM
Cropper Cropper is offline
https://www.flickr.com/gp/136904711@N05/g214a2
Old 11th December 2016, 07:34 AM
Dave F's Avatar
Dave F Dave F is offline
Originally Posted by Cropper View Post
If you check out the last 3 pictures you can see the radiator air deflectors in place. The left & right bolt onto the side of the radiator nicely. I also managed to use the MX5 fab on the merc rad, again this bolted on nicely, my donor had a/c so don't know if the fan is the same as the rest. Hope this helps your decision.
Thoses deflectors look good, I'd planned to make them out of plastic but I'm liking the look of the alloy. I'm still leading towards the Merc as I often find myself in traffic for no reason so for the small extra cost it will give me a little bit of peice of mind.
God loves a trier
Actual cost so far = Have chosen to stop counting incase I incriminate myself -
Cost ive told the wife = A hell of a lot less than I have spent. -
Old 11th December 2016, 09:18 AM
Ianr Ianr is offline
Originally Posted by Dave F View Post
So is it T'ed into the top rad pipe, that's what I was thinking but not sure if the system would function as it should.
Yes that's correct - and it seems to work fine with the fan cutting in after being stationary for what seems ages and then cutting out shortly after (standard MX5 fan)
Old 11th December 2016, 09:24 AM
I have put deflectors in the nose to help the air decide that it should go through the radiator rather than round it!
I like your Renault Scenic center rear seats - I used the outer pair from the same car - very comfortable indeed
Old 11th December 2016, 03:32 PM
Thanks, the seats work well & were a bargain, one cost £10 the other was an extortionate £30, runners were off a smart car, eBay special!!
When I took the car for it's Iva, there was lots of idling time but very little fan cutting in, it had to be encouraged to get hot to prove the fan worked!
