Old 30th April 2009, 10:15 PM
snapper snapper is offline
Simply buy a non LSD Lobro diff and swap the Lobro shafts
Old 30th April 2009, 10:21 PM
Cobra289 Cobra289 is offline
That is just what I did and you can see the result at the second picture.
The drive flanges will not fit.
Regards,
Cobra289
http://www.donostia.demon.nl
'Improvement' means that you recognize previous mistakes!
Old 5th May 2009, 09:58 PM
Bump! Any help?
Old 7th May 2009, 10:36 PM
There are 2 sizes of diff 7" and 7 1/2" there are also 2 sizes of Lobro, 100mm and 108mm diameters.
There are at least 2 thicknesses of drive shaft as well.
I think at this stage i would fit any diff that i had and save the LSD for another day post build
Or
take it to a diff specialist, it may be a simple fix for them.
Andy Bates at AB performance has a diff man he uses for swapping crown wheel and pinions to produce a 3.3 or 3.1 LSD, worth a call to him.
