Old 30th April 2009, 11:45 PM
zrblue zrblue is offline
what it means is when you strip the donor then take the vin plate off the body aswell as its useful when the time comes for IVA test as it proves the donor parts came from the said vehicle on the paperwork you will have to submit to register/test your completed new car.
hope that makes sense?
Ah...so the VIN transfers onto the Roadster?
Old 30th April 2009, 11:49 PM
erm, well kind of, if you want an age related number plate then you have to prove that your car was built with a certain amount of parts sourced from one donor car & having the vin plates helps you prove thats what you have done, along with lots of photos of your build & photos of you stripping the donor etc, you won,t get to use the same reg number of the donor but will get the same year affix that the donor had, ie... G reg sierra = G reg Roadster.
Old 30th April 2009, 11:52 PM
It seems like an awful lot of hassle to get an age related plate...is there some benefit to be had by having an age related plate over a Q plate?
Old 1st May 2009, 12:00 AM
ah now thats another subject discussion all on its own, basically if you can prove the origin of your donor parts & engine it makes it easier to get thru the iva test, also helps prove the engine age which then determines the emissions test that your Roadster would have to pass, along with when time comes to have the car mot,d, if the age of donor was pre 1993( i believe) then you won,t need a catalytic converter for emissions etc ( less cost), when you do buy a sierra & strip it then just keep it sorned, do not notify dvla that its scrapped. lots of info available on threads in the donor section of the forum.
hope this explains it a little.
also some say a Q plate is worth less than age related plate , but thats to each persons opinion.
Old 1st May 2009, 12:03 AM
alright, thanks Andy, that clears it up a bit for me...ill read further in the IVA/Doner sections.
