Old 3rd August 2009, 10:31 PM
les g les g is offline
why yes just use stainless rivets
cheers les g
Old 4th August 2009, 08:55 PM
Beardy_John Beardy_John is offline
damn, why didnt I think of that! And from my datasheets, should be quite a bit stronger than the standard alu/steel rivets
www.beardyjohn.com Build blog and associated ramblings (Updated - 17/07/09)
Old 4th August 2009, 09:03 PM
Thanks guys, guess where i,m going tomorrow??? stainless shop
Old 4th August 2009, 10:27 PM
jerkins's Avatar
jerkins jerkins is offline
cheers les g
As long as you've got arms like Popeye...
Old 4th August 2009, 10:39 PM
or an air powered rivet gun
Old 4th August 2009, 10:44 PM
well i used to be a sailor in the Merchant Navy.... does that qualify me?
Old 4th August 2009, 11:32 PM
air powered rivet gun is the way forward. i got mine from axminster for £45. was worth every penny when i did the floor on the weekend. its the first time i have done large amounts of riveting and not felt dead by the end of it.
Old 4th August 2009, 11:43 PM
what size compressor would i need for the air powered rivet gun? i,ve seen a complete kit in Aldi, would that be upto the job?
Old 5th August 2009, 09:32 AM
The rivet gun should state a rated pressure and flow per minute (cfm I think). Even a small compressor should be up to the task, 25L sort of size, it's not like you'll be firing it off 100 times a minute or anything
Old 5th August 2009, 09:40 AM
most compressors will run one they require very little air.
