Old 31st August 2009, 11:35 AM
Peter-C Peter-C is offline
Default Removing driveshafts
I'm struggling removing the driveshafts. The donor is an estate and I've removed the whole rear subframe. I've removed the hub nut and the 4 bolts that secure the hub carrier and brake backplate to the lower suspension arm. You should now be able to pull the whole drive shaft assembly out but it seems too big to go through the hub.
Any ideas ?
Pete
