Old 6th September 2009, 07:35 PM
andyuk697 andyuk697 is offline
Default not square
hey all
after a bit of pratice welding i finaly got the courage to spot weld the first 4 pieces today, they are all cut perfectly to the mm and just cannot get all 4 corners to perfect 90 degrees square i have used welders magnet a digital angle setter and a solid steel 300x600 square to check them.
what am i doing wrong?
Andy
Old 6th September 2009, 07:42 PM
are you talking about the 4 main lengths in the base of the frame?
if so have you put the little blocks on your build table to hold everything still whilst you weld?
Old 6th September 2009, 09:28 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Also check diagonals and straightness of the tubing and obviously each pair of opposites should be exactly the same lenghth when held up against each other
Ray
Old 6th September 2009, 09:37 PM
hi
thanks for the replys yeah its the first 4 pieces on the bottom rear part they are perfect lenth and each pair is identical lenth as theyre only tackt i can adjust slightly with my rubber mallet but everytime i adjust one angle it moves the other
also each angle diagonally across is the same somthings obviously out but i cant figure out what
if my hair was long enuff id be pulling it out lol
cheers Andy
Old 6th September 2009, 09:41 PM
suggest taking the tack welds off, then clamp each piece to the build table, check for true square before putting any more tack welds on,
maybe the table is not "true"??
Old 6th September 2009, 10:36 PM
i will try that tommorow thanks
Andy
