great drawings there Ash, great great help.
cheers Samy |
dont say thanks to me say thanks to westfield world they are a great bunch of chaps for producing the pictures.
thank you westfield world
hey handy andy, what size head lamps did you use?
Cheers Samy |
the measurements i,ve used for the headlamp brackets have taken into account that i can use either 7inch or 5. 3/4inch headlights as they both still conform to the spacing requirements of the IVA for the spacing from the widest part of the car, tho i did think of using the more modern 4inch lights but these wouldn,t have met the distance requirements with the length of my brackets.
andy ![]() |
thanks andy, my head lamps are going to be 146mm so i think the measurements you had should be ok but i´ll give the guy from the sva a call tomorrow just to be sure we have the same rules here
cheers |
where is "here" ???
hope my measurements are ok as a guide andy |
#18
i´m a little north of you in Sweden
cheers andy |
#19
Ash,
I,m confused by the 7 degree angle, are the supports horizontal with the frame and the angle makes them parallel with the front frame. Or are the brackets angled up or down from the horizontal, if you get my gist. Please see attachment. Peter |
#20
Hi Peter,
hope its ok to respond as not sure if Ash is online till later in the evenings..... the 7 degrees is as your diagram A, so that the stalks are parallel with the front frame, the stalks are set at the horizontal level with the top of TR1 & TR2. sorry if i shouldn,t respond but thought you might be working on your chassis this afternoon cheers andy |
| Thread Tools | |
| Display Modes | |
