Old 2nd November 2009, 10:10 AM
Rik178m Rik178m is offline
Ok cheers
Is this sufficient? http://www.autosportlabs.com/megajol...self-p-39.html
Old 2nd November 2009, 10:42 AM
Originally Posted by Rik178m View Post
Certainly looks like the right one, but I think AshG is using MJ, so you could drop him a line.
Sean
Old 2nd November 2009, 11:15 AM
Yep that's the one I built
Quick tip !!
If you are not sure if you need the MAP or TPS version. It would probably be best to buy the MAP version & order the TPS component pack at the same time.
This will make sure that you have all bases covered
Old 6th November 2009, 02:52 PM
hmmmmmmmmmm a what version lol? What do they stand for and which would I need?
Old 6th November 2009, 04:01 PM
correct autosport labs is the one. if you are using buke carbs you will want the one with TPS. if you get the december issue of complete kit car i have done a nice little write up of how it all works in relation to each other.
