Old 3rd November 2009, 03:50 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, not sure what it is for your carbs but if you look at the float chambers where they split apart the gaskets should sit horizontal in normal use
heres a pic of mine at approx the right angle if it helps
Ray
Old 6th November 2009, 07:32 PM
Well after a couple of modifications to my first manifold the carbs are now attached to my engine
Heres a couple of pics for you, my build is starting to see some light at the end of the tunnel now
Old 6th November 2009, 07:46 PM
looking vey smart Mark, just wait till your bodywork is fitted
hope you,ve got some shades at the ready it looks great
ps ... what you doing on sunday? fancy helping moving a Roadster?
Old 6th November 2009, 10:45 PM
look good mate did you tap them to tale balancing tubes?
Old 7th November 2009, 09:36 AM
No i didnt, i always thought you could balance them by shoving one of those carb balancer thingymjigs in the end of the trumpet?
If not its no big deal to add them in if i have to, as usual any advice on this subject greatly appreciated
Old 7th November 2009, 09:39 AM
Only too happy to help mate, just let me know what time and i will be there impact gun in hand! we will reduce you car into a pile of parts in no time you have actually picked a good weekend for it as im not working and my van isnt crammed full of parts for a change.
Old 7th November 2009, 05:12 PM
RAYLEE29's Avatar
Looking good mark and your bonnet should still miss the carbs (hopefully)
have you had it running yet?
if you can tap the runners to take vacuum gauges it will help setting up the carbs using gauges as opposed to those flow meter things (its a lot quicker and more accurate) thats if you have access to some.
Looks like youll be able to move under power soon thatll be a great feeling.
Ray
Old 8th November 2009, 05:08 PM
Ray
Not run yet but thats next on the never ending list of things to do! Megajolt and start sorting out the wiring. I will put some points in for vacuum hose if thats the best way to do it. In my work i take pressure readings in ductwork so have digital manometers so maybe i could use those for setting the carbs.
Old 8th November 2009, 06:37 PM
RAYLEE29's Avatar
Yes im sure you could use digital manometers you might need to use some form of damper as on the anologue gauges i have with no damping they flutter around alot you can get a similar thing for adjusting air pumps on aquariums if you find you need some
Ray
Old 10th November 2009, 04:44 PM
snapper snapper is offline
check your hoses as i understand some silicon hoses are not fuel resistant
