Old 22nd November 2009, 07:09 PM
I seldom find the need to use filler rod on a close fitting corner joint ( Must be tight with no visible gaps )
I think it is purely to do with the correct set up & weld procedure.
Yes I took a gamble on a Cheap Chinese import, I know that some of them have a dreadfull reputation.
The price was worth the risk (ish)
The model I bought was a WSE200. ( "Giant" Branded set )
200 amp AC/DC inverter.
60% duty cycle
HF start
Pre & post gas
Slope up & slope down
Cleaning width adjustment
£395 including free delivery & foot controller
It has a surprisingly smooth AC output & very fine current controll.
Time will tell as to wether it lasts the distance or not
If it does all of the work planned for my build, it'll owe me nothing !!
Could of had a used commercial set for not a lot more but was unable to locate a good second hand unit locally ( Fetch silly money down here )
Old 22nd November 2009, 07:21 PM
Yep you are correct Ray. I just fused the edges together.
Filler rod can be a bit of a nuisance at times........ If you are not extra careful & if too much filler rod is introduced to the weld pool, the pool tends to flow too quickly & can cause poor root penetration or hidden cavitys in the weld.
Old 22nd November 2009, 08:39 PM
Man's a proffesional !
