Old 5th December 2009, 01:56 PM
Tatey's Avatar
Tatey Tatey is offline
I've got 1 sorted now using the cut and shut method. Oh how i've missed Mr Angry Grinder . Cheers for the help guys.
Old 5th December 2009, 02:16 PM
nice one Simon
"where there is the will there is a way"
where else would you get such a quick response to your thread ????, within minutes you had 3 forum members reply to your frustration & with photos too
Old 5th December 2009, 05:51 PM
Tilly819 Tilly819 is offline
hehe, i cheated with mine, went down to the local pipe man got 4 19mm manderil bent 90 deg elbows then just cut the tube and welded them in worked a treat
Tilly
Old 5th December 2009, 07:36 PM
I never even attempted to try and bend mine in one piece..........Far too lazy to try & work out the geometry of it all
I used 4 long'ish bits of tube, put 90 degree bends in the middle of each one & then cut to width, then welded them up.
The rear panel bent round a treat & looks the part
Old 5th December 2009, 07:39 PM
Tatey's Avatar
I got the second one done earlier, i just need to cut them down slightly to make them the perfect size . I can't believe i didn't think of cutting them and welding them together from the beginning.
Old 5th December 2009, 08:27 PM
andyuk697 andyuk697 is offline
i just want to say thanks for posting this thread i will be tackling the rear tubes on monday and now i think i will also use the cut and shut method
cheers Andy
Old 5th December 2009, 08:32 PM
If you are in the mood Simon I would be gratefull and gladly pay for 4 corners bent to shape.
Old 5th December 2009, 08:33 PM
Tatey's Avatar
I'll be returning the conduit bender to my mate tomorrow night, so ill happily go out and get them sorted for you, you've been a great help in my build so far and im always one to repay a favour. Ill be able to bring them along on monday afternoon if that suits you?
Old 5th December 2009, 08:40 PM
Thanks Simon that will be really helpfull and save me a bunch of hassle and if you are stuck dont hesitate to let me know.
I wont be in Monday as I am going to my daughters graduation ceremony and then celebrating so just when ever suit's you is fine as there is no panic.
Thanks again.
Old 5th December 2009, 08:46 PM
Tatey's Avatar
Feel free to pick a day , im in newcastle on Wed, Thurs and Fri and finish at 1pm, 4.30pm and 1pm.
