Old 28th December 2009, 04:08 PM
Originally Posted by dogwood View Post
If I was starting again I would defo use the "HandyAndy"
Saves an awfull lot of agro.
Thanks David,
Ash, i might be an odd shaped little man , but am more than happy to cut steel for folk
For any folk thinking about starting a build, i,m always happy to help if you decide to go for the flat pack route
Old 28th December 2009, 04:49 PM
Well a bandsaw or Mitersaw is going to cost a fair bit on top of the steel..
I personaly would not use a angle grinder as a general cutting device. To brutish, to noisy, to crude. To messy.
I do have a B&D scorpion reciprocating saw which has cut up a few cars.. It can be hard work, and the blades wear out fairly quickly considering their cost.
Old 28th December 2009, 05:51 PM
Dusty Dusty is offline
this is the one i've just got
http://www.diy.com/diy/jsp/bq/nav.js...&isSearch=true
Ive been told it will do the business, so i will test and see. As for the lenght of the steel i'm getting 42m 25box, 18m 19box, 18m 19 tube.
Old 28th December 2009, 08:05 PM
has that actualy got a proper ferous blade?
Old 28th December 2009, 08:33 PM
i dont know myself but the guy at B&Q said it would work. I did tell him what i was using it for and the details and he says it will be fine ...
Old 28th December 2009, 08:36 PM
I bet it's just a wood blade.
Old 28th December 2009, 08:57 PM
I would do some research before atempting to use that mitre saw. I have done a little research and can't find anything that sugests they are suitab;e for cutting metal.
Using the wood blade could result in some rather alarming, life endangering, trouser wrecking incidents..
Old 28th December 2009, 09:26 PM
graeme.webb1@ntlworld.com graeme.webb1@ntlworld.com is offline
To the best of my knowledge you can get metal blades for them. However they seem to have less power than the average cut off m/c that I have used. Could be good for the compond angles.
Dusty ( Hi by the way & welcome to the forum)...
i,m no expert on machinery but i very much doubt that saw will cope with cutting almost 42mtrs of box steel, its not so much the blade ( tho that is critical to the type of material being cut, must use a blade designed to cut steel), its more to do with the torque reaction of the motor in the saw.
i used a Fury3 compound mitre saw for a while but found it went thru blades too quickly, & so we at Saturn now have a professional cutting disc mitre saw, the kerf is a little more but the blades last alot longer, i also use a 1mm cutting disc in an angle grinder for the more acute angled cuts.
without telling you how to suck eggs, i,d take the advice from a shop salesperson with a pinch of salt & trust forum members opinions who have cut the same steel you intend / need to, maybe save you money & hopefully an injury.
i hope that doesn,t come across as rude, just hopefully helpful.
( i,ve now cut over 500mtrs of steel for chassis kits).
Old 28th December 2009, 09:48 PM
put it this way, if you chip a wood tooth spinning at 5000 RPM off the blade.....................
Metal needs to be cut slower with a fine toothed blade.
I doubt even staff at somwhere like machine mart will know what's what..
If there's an advice line in the packing give it a ring.
Evolution produce some tools that specify metal cutting..
http://www.evolutionpowertools.co.uk...ion_rage3.html
