Old 18th January 2010, 11:26 PM
Originally Posted by Jezzer99 View Post
Hmmm... it makes sense the more I think of it; it's one less twisting force on the diff so I think I'm going to do it
hmmmm i think i,ll be making up a bracket tomorrow then
Old 19th January 2010, 02:03 AM
The main function of the rear diff mount on the Sierra is to provide the third, rear, attachment point to the subframe. It is has a generously moving rubber bushing, so I doubt you would transfer much torque through there.
Incidentally, I've been browsing the Caterham assembly instructions today, they have this mount point chopped off altogether on Sierra diffs.
Old 19th January 2010, 07:37 AM
dogwood's Avatar
dogwood dogwood is offline
Thank's for all the replies to my OP.
I think I knew the answer all along.
I guess I was just hoping someone would dissuade me from the obvious
As for the rear bracket.
When I first put it together, it just seemed the right thing to do.
I put on the Sierra rear bracket, and it fell right into place of RS6.
So I bolted up a plate to the diff bracket, and welded it in place.
David.
Old 19th January 2010, 09:54 AM
That's a very good idea with the 3rd bracket for the diff David, it now looks much more secure and is fitted the way it was designed. We're also (some of us ) putting more power / torque through the mountings than they were designed for.
I'm about to upgrade to an LSD and will be adding the 3rd support during the upgrade..
AndyH
Old 19th January 2010, 04:35 PM
dogwood's Avatar
See, I do have some good ideas......
It's a shame they get lost in all the rubbish ideas I have
David.
Old 19th January 2010, 06:14 PM
Davey's Avatar
Davey Davey is offline
As I'm fitting a 2.9 Cosworth with ITBs and Emerald management along with a LSD Granada diff I've fitted the rear mount too. Mine is a bit different to all yours 'cos its a Locust rebuild but it seemed to make sense with the potential of around 200 ft/lbs of torque from the engine. By the time this gets to the diff it could be significantly more in the lower gears so the stronger its mounted the better in my book. Admittedly as the diff is solid mounted and this mounting has a big flexible rubber bit in it I doubt if it will make a huge difference but if one or more of the other mounting points breaks away it might just prevent total carnage at the rear.
D.
Old 19th January 2010, 08:51 PM
dogwood's Avatar
Chassis plates CP10's now replaced with 5mm ones.
Wasn't as bad to cut out the old ones as I thought.
NOW I can start painting...........I hope.
Sick to death of bl***y welding.
David.
