Old 2nd March 2010, 09:53 AM
Tilly819 Tilly819 is offline
hi there,
as regards reverse it actualy quite simple once you get your hear round the concept, my consits of a cut gear mounted on the diff input flange, and a starter moter mounted in the bottom the the transmision tunnel which engages and disengages on the bendix, the live to the motor is conected direct to the battry the frame is the earth just like normal then run the solinoid threw a normaly open on a rely to a fuse then the coil of the relay is operated with a perminant live from another fuse then a switched Ov intersepted from the nutral light with a simple button on the dash, there are some photos on the forum somewere already il see if i can find them for you, i notice you are not to far away you are more than welcome to pop over of you want to have a look.
tilly
Old 2nd March 2010, 02:30 PM
layotn20 layotn20 is offline
when i get to that stage, we will have to meet up. because for me its better to actualy look at 1 set up.
oh and good look with your iva
