Old 6th March 2010, 04:49 PM
geeman's Avatar
geeman geeman is offline
What engine are you using, and what have you done with the engine loom?
ive got a 1.8cvh. Ive got it to turn over, and was being an idiot earlier, as i wanst looking at the ignition coils in my last post. Ive now found the ignition coils, and the plug from the edis connects to it. I now seem to have the ignition coils sorted, however when i was trimming my loom a mont or 2 back, i cut off all the plugs to the steering column, including the ignition switch. I am now wondering what i am meant to connect the black/yellow wire to that is on the ignition switch. I know the blue/black one goes tot he starter solenoid, but i dont know about the yellow/balck one.
Ill be asking alot of probaly very obvious questions as i dont know much about wiring this engine. Thanks
Edit: just saw your other post. i have connected the plug fromt he front body loom to the +12v. Now to figure out what the yellow.black wire is meant to be? it goes to pin 10 of the edia and the engine managemnet relay according to the haynes diagram
my build pics
Old 6th March 2010, 04:54 PM
DaddyA's Avatar
DaddyA DaddyA is offline
If you haven't got a manual, i've got an electronic version of the wiring i can send if you want??
Daz...
Old 6th March 2010, 04:55 PM
geeman's Avatar
I have that, its just im still no good with this wiring
my build pics
Old 6th March 2010, 04:56 PM
EDIS? Are you runing megajolt?
Black Yellow, Goes to the ignition relay and fuse 20, 21 , 22.. Maybe some more items but bascaly It's Ignition Live Feed.
Old 6th March 2010, 04:58 PM
DaddyA's Avatar
you'll just have to do a bit at a time, be careful because the wires tend to change colour as they go along!!
Daz...
geeman's Avatar
umm.. sorry again, didnt mean to say edis, meant to say hybrid ignition module. , imm really not doing to well here am i
my build pics
Old 6th March 2010, 05:02 PM
geeman's Avatar
ok, for the time being, as i dont have an ignition swith, and am just trying to get the engine running, can i just connect the black/yellow to 12v and that to the relay and the hybrid ignition module, ?
my build pics
Old 6th March 2010, 05:06 PM
Do you have the engine loom with the three multiplugs ( 4, 6 , 8 pin ) Still intact.
It's 10 years since I have worked on a CVH but the wiring to the engine hookup is the same for all post 90 cars.
Old 6th March 2010, 05:07 PM
geeman's Avatar
are those the 3 that join the main loom to the engine loom. I have attached the 4 and 6 pin ones, however, i cant find anywhere to attach the 8 pin one. Thanks for the help so far!!!! Also i just realised that relay that the starter solenoid wire is connected to is an auto trans relay? WHats this for considering i dont have auto trans?
my build pics
Old 6th March 2010, 05:22 PM
There's 2 different loom diagrams for the 1.8 CVH manual ( GR8!! )
Do you have Relay X1 or not?
