Old 10th March 2010, 01:49 PM
Hang on a few minutes and i,ll get the measurements for you.
Old 10th March 2010, 02:02 PM
Hi Russ,
the width between the transmission tunnel & inner face of the side of the chassis is 45cm,
the length from the brake pedal to the center of the seat (backrest/spine area) is 126cm.
obviously the actual pedal box plate is further forward than the brake pedal but thought the point from the brake pedal at natural rest position gives a better measurement to work from for you.
The above measurements have been taken from Spuds car, & as said he is 6ft 7in tall.
hope this helps.
Old 10th March 2010, 02:09 PM
Enoch Enoch is offline
Hi Russ, I am in Bracknell. My chassis is far enough along so you could come and have a sit in it and see what it feels like size wise. Drop me a pm if you want to arrange.
Enoch (Dave)
Old 10th March 2010, 02:19 PM
Russ_16v Russ_16v is offline
Hi Russ,
hope this helps.
Andy, i cannot thank you enough! I will template those measurements out tonight, im pretty sure that should be fine, again i really appriciate that! And just to check, that is a standard size chassis, made to 'book size'?
Enoch (Dave)
HI Dave, thank you so much for the offer, your about 1/12 hour from me which is a little far to go at the moment, but i will keep you in mind, thats really kind of you
Old 10th March 2010, 02:24 PM
No prob Russ, happy to help,
Yes those measurements are taken from a standard "book spec" chassis.
if you need any other measurements just shout.
Old 10th March 2010, 02:30 PM
I know this is really cheeky, but could you give me the measurement from side to side? As in from one side of the inner chassis to the other, so i can see the total width of the body? Any pictures of this car?
Again i cannot thank you enough
Old 10th March 2010, 02:54 PM
the width between the inner edges of the outside chassis rails = 106.2 cm & the transmission tunnel is 17cm (clad in aluminium) central in the car.
There,s alot of pics of this car on our website www.saturnsportscars.co.uk
no prob
Old 10th March 2010, 02:58 PM
Fantasic, thank you again Andy!
I will drop you a PM about a few things shortly if thats ok?
Old 10th March 2010, 03:03 PM
no prob, just let me clear my PM box, it fills up too quick
Old 10th March 2010, 04:18 PM
PM sent
Now on the look out for a Sierra, is an XR4x4 any good?
