Old 19th March 2010, 02:59 PM
Use something to mock up the shockers the same diameter and length and put it in place and see what it looks like and this will give you some idea of what will fit,plastic drain pipe ?
Old 19th March 2010, 03:01 PM
layotn20 layotn20 is offline
cheers m8 nice 1
Old 19th March 2010, 03:04 PM
Anytime dude
Old 19th March 2010, 09:38 PM
Tilly819 Tilly819 is offline
just out of intrest were does the lower section of the steering collum come in relation to the off side shock with the inboard setup...there carnt be much room for it
chears tilly
Old 20th March 2010, 08:25 PM
isn't to bad mate as the suspension bolts in the middle of the chassis at the bottom about 5/6 inches behind the steering rack. and the colum is rite over in the off side corner, if that makes any sense to you
Old 21st March 2010, 07:39 AM
dogwood's Avatar
dogwood dogwood is offline
Originally Posted by layotn20 View Post
so as long as i buy 4 dampers that are 13" open il be ok?? im having 250lb springs on front and 300/350 on back.
Wrong way around.. 350's at the front, unless you are using a bicycle engine
David.
Old 21st March 2010, 11:21 AM
using a zx9r engine. so 350 on front?
