Old 19th January 2013, 12:34 AM
Any 4-hole Ford wheel should do, including ones from Escorts, Focuses and early Mondeos. From 2001 Mondeo switched to 5-lug pattern.
Old 20th January 2013, 12:44 PM
Thanks, no excuse for me not to pick one up and start making that spare wheel bracket when the snow clears.
Appologies for highjacking the thread.
Old 23rd January 2013, 11:22 AM
iDriver iDriver is offline
As some of my questions are answered in this reenergised thread I hope the OP doesn't mind me jumping in with a question.
I have obtained a rolling chassis for a now out of business Venom GT2 and rather than reinvent the wheel (no pun intended) I am planning on modifying it to a roadster style all be it a few inches wider and longer than the book.
This rolling chassis has obviously got heavier and different shape wishbones and backplates to the book and so wheels are not going to be a simple case of copying what others have fitted.
The hubs and brakes are Granada Scorpio units and the rolling chassis came with some 5 hole steel wheels on the front and 5 hole alloy wheels on the rear. The wishbone setup will not allow the smaller steel wheels from the front to fit on the rear but the larger rear wheels will fit on the front.
SO.... Question.. Given that the rear alloys look to be the standard Granada Scorpio units. would after market alloys that claim to fit the Granaga be guaranteed to fit and have the same internal clearances (i.e. will they clear the wishbones) or do I need to measure the original Granada alloys and start from there?
Old 23rd January 2013, 12:21 PM
rpjg1975 rpjg1975 is offline
I would think u will be safe doing that. Also I believe later Mondeo or later shape focus will also fit those hubs. Would be worth checking the specs or someone may be able to clarify the exact figures
Russ
Old 23rd January 2013, 02:38 PM
TSM Locost's Avatar
This site will give you details of wheel spec for you to compare, eg stud PCD pattern, centre hole and offset.
http://www.alloywheels.com/Alloy-Wheels-Fitment-Guide
Be Lucky, Mike.
