Old 12th April 2010, 04:51 PM
Default oil pressure / temp gauge
Hi all,
I,m about to fit an Oil pressure gauge & an Oil temp gauge, obviously I know where the original pressure point is on the block, so was thinking if its poss to fit both senders for pressure & temp from the same place on the block, or is there another outlet i should use for the oil temp sender?
I,ve read that i would need a "sandwich plate fitting" to connect both from the same outlet but its very close to my engine mount & don,t think i,ll be able to fit anything that size so close to the mount.
any suggestions ?
engine is the 1.8 CVH
