Old 19th May 2010, 07:00 PM
drury318 drury318 is offline
I have put some photos on photobucket, see if you can see them, not quite sure if the link will work, Dennis.http://s836.photobucket.com/albums/zz286/drury318/
Old 19th May 2010, 07:07 PM
gingea1pom's Avatar
Drury,
Well done on the pass, hope you don’t mind I put a pic on the page
[IMG][/IMG]
Cheers Ginge
Build Pictures
Old 19th May 2010, 07:08 PM
Fanmadgeatastic...
Old 19th May 2010, 07:29 PM
Cracking result - well done you!!
Can I ask, do you have a Zetec engine installed, and if so where did you get your exhaust from?
Well done again!
Adrian
Old 19th May 2010, 07:39 PM
David_17's Avatar
David_17 David_17 is offline
If you do have a zetec installed, is it running on injection with a cat?
Old 19th May 2010, 07:43 PM
Hi Adrian, yes it is a Zetec engine, the exhaust was from Martin Keenan in Maltby, I mocked up a sort of jig using a manifold plate from GBS Robin Hood and some flat bar then took it to him as he lives only 30-40 mins from me.
He may do the same for you if you call him, he will explain what I did, tell him Dennis RAC man from Scunthorpe & he`ll know who you mean.
It`s really well made & looks the dog`s whatsits, I just need to remove that heat wrap! Dennis.
David, it`s runnung on Suzuki throttle bodies, Canems ECU & no cat as it`s Feb `92 engine
Old 19th May 2010, 07:54 PM
Enoch Enoch is offline
Well done that man, great to see another one has passed. Must get my finger out and get some garage time in so I can get mine through
Best and all that,
Enoch
Old 19th May 2010, 08:07 PM
slimtater slimtater is offline
Well done on the pass - let me know when it is all sorted and I can get you a build plaque. Sorry, but I think you are no. 13!
Old 19th May 2010, 09:31 PM
Headshot Headshot is offline
That looks bloomin' brilliant (PG language mode engaged)
I hope beyond hope that my build is near that in looks
Well done
Failed builder
Old 20th May 2010, 09:12 AM
Well done on a first time pass,obviously well built.
