Old 28th May 2010, 07:58 PM
Headshot Headshot is offline
And thats an original 1960's mountney wheel in there used it in all my mini's prior to getting one with an airbag
Failed builder
Old 28th May 2010, 08:43 PM
I have just had a tought Andy !!
That wouldn't be the single seater you were talking about building at Stoneleigh by any chance
Old 28th May 2010, 08:45 PM
Headshot / Ronnie
Thanks Headshot, once i,ve read & re read the instructions i know where to come if i get stuck
I,ve already thought about repositioning the headlights, & i,ve only just received the plans today.
Ronnie....... I,ll be honest & say that i quite like the idea of the Roll bar, apart from safety of the nipper it,ll look even more like "dads car"
I just thought for £15 it was worth a punt at making it , ...........
Now, where is the jig for the front frame ????? LOL
Old 28th May 2010, 09:59 PM
Oops..missed this post
call it a trial run
Tho, I will be making the real Single Seater too..... i best get the Roadster finished first tho
Old 28th May 2010, 10:36 PM
I also picked up the wheels from the guy who makes the plans.
One major problem I have found is the level of grip at speed is so high my little girl (2) is nearly thrown out, I currently have the car sat on my roadster build table trying to work out roll bar and seatbelt arrangements!
Have clocked her at 4mph in 1st gear and 10mph in second... which for a 2 year old is too fast (especially when she doesn't quite understand steering yet )
Failed builder
Old 29th May 2010, 11:13 AM
I built one of the old type also.Was good little project and no.1 loves it.Only problem i found was the old type used a wooden door knob for the steering wire to wrap around and it would slip so i extended the steering column and bent it round at 90' to form a hook and then drilled through the axle and put a u bolt there for the hook to locate and do the steering.
Old 29th May 2010, 11:27 AM
Cheers Ozzy,
I,m sat here right now reading the build manual
& I thought the steering mechanism was a little suspect so will be doing something similar to what you did to make it a more positive steering system.
I wonder what its self centering would be like , I,ve thought about putting a bungy cord ( under tension ) into the steering so that it will always self center . do you think that is worhwhile ?
Old 29th May 2010, 11:56 AM
Iwouldnt bother as mines always turning the wheel to chase the other 2 buggers or the cat
Heres a pic also of a kiddie car from the shop that i copied the idea from,might make more sense than my explanation!!
Old 29th May 2010, 08:02 PM
This part is now changed to a rubber door stop and 2 LARGE washers, works a treat, no slip
Failed builder
Old 29th May 2010, 08:27 PM
I spent an hour reading the instructions in depth today, got my head around it
Swmbo has even been out & bought our little lad a "Racing driver suit"
I best get cracking on it,
I suggested it should be tango orange like my car, wife says "silver & black stripe"
