Old 24th June 2010, 11:19 PM
Pavel Pavel is offline
Default Inboard suspension
I'm trying to get the roadster chassis into solidworks at the moment to have a play around with packaging inboard suspension if possible. The only problem appears to be the steering rack at the moment..
Initially I was just hoping to do it at the front, but am now looking at the possibility of mounting the rear shocks into a central node above the rear diff. Will also be modifying the rear suspension frame slightly (not dimensions wise) as the lack of triangulation bothers me slightly.
Has anybody managed to use pushrod suspension on a haynes roadster?
