Old 15th July 2010, 10:06 PM
David_17's Avatar
David_17 David_17 is offline
Default D1 D2 D3 & D4
The diagonal chassis tubes mentioned in the title are thinner box section than the other chassis tubes (as you will know).
Just wondering, do i line them up central with the 25mm box or flush with the outer edge of the chassis?
Also should i weld the uprights first before fitting them? They're only tacked at the moment, and i might have to grind the tacks back a bit to give enough room for the diagonals.
P.S. I've just updated my build blog if anyone's interested in having a look at a few pics.
http://davesroadster.blogspot.com/
*updated 7/6/11*
