Old 23rd July 2010, 12:09 AM
davidimurray's Avatar
I remember asking Chris about this before and he confirmed they are wrong. The 71 deg to the top chassis rail in Fig 4.20 is correct. I have a memory that SW3 is the tube that needs the angle altering - but I can't be 100% sure. If you don't get an answer beforehand - I can check the angles on my car on saturday
Old 23rd July 2010, 12:11 AM
David_17's Avatar
David_17 David_17 is offline
Ok. Cheers, if noone can confirm the angle before tomorow evening, i'll try connecting all the other bits up then cut SW3 to fit. Should work
*updated 7/6/11*
Old 23rd July 2010, 12:20 AM
Just had a quick look at the book - end of SW1 is cut at 23 deg - which when you work out it comes to 90-23 = 67deg and not 71. Hence I think it may be SW1 you need to cut to 19 deg instead.
Old 23rd July 2010, 10:11 PM
David_17's Avatar
Thanks to your help, i managed to get it sorted this evening... however... I balanced a seat in the car (on 25mm box section) and sat in it for the first time, problem is, my eyes are inline with the top of the steering wheel.
After IVA i'll be putting a smaller one on, so shouldn't be a problem, but what about iva man?
Anyone else have this problem? (rack isn't height adjustable).
One other question for this evening, can anyone give me a clue to where these plates go?
[EDIT] Had a look at some pics, and i'm guessing cp8 goes at the back for the fuel tank to sit on? and one of the cp14s at the back of the transmission tunnel for the handbrake cable. What about the others??
*updated 7/6/11*
Old 23rd July 2010, 10:46 PM
Eternal Eternal is offline
cp14 goes in the center area of the diff cant remember what its called now... anyhow it holds he handbreak cable ect, The large triangle plates with the edges cut are for the ally rear tub same with the little squares with holes. dont have the book to hand but if you look in the rear tub section you will see them. As for the long triangles cp24....... well i have yet to find out
Skyline Roadster
Old 24th July 2010, 09:55 AM
David_17's Avatar
Great. Thanks for the help. Do both CP14s go in the diff area?
Also anyone else had problems with steering wheel or seat height?? Or are you all tall?
*updated 7/6/11*
Old 24th July 2010, 12:58 PM
james3004's Avatar
I think you only need 1 cp14 for the handbrake
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 24th July 2010, 01:24 PM
les g les g is offline
CP24
front of engine bay
where the engine rails meet the outer rails
they are like a fillet to reinforce the join
br1-br8 and br2-br9
cheers les g
Old 24th July 2010, 02:31 PM
cp 14 - 1 off req to locate handbrake cable(slot both holes to slide cable in easily)
cp9 - 2 off ( square with square cut out & hole in) roll bar support plates
cp8 2 off fuel tank supports
cp25 2 0ff (larger triangle) below cp9 to strengthen cp9 supports
cp24 as les g said
Old 24th July 2010, 03:54 PM
CP9 & CP25 only needed if you are fitting an ali rear tub, but if fitting a GRP tub you,ll need an extra frame layout to attach it to ( see other thread/posts about the layout).
