Old 14th August 2010, 08:59 PM
Originally Posted by mr henderson View Post
AND who knows how long the springs were before they fitted them.
That is 1 dimension that I just can,t remember from my build, BUT I,ll happily dismantle my suspension tomorrow & measure it for you Sam
Tho my engine is only a little 4 pot
A good suspension set up really "makes" the car, so worth getting more experienced info from spring/suspension "guru,s".
all the best
Old 14th August 2010, 10:26 PM
Springs are 8" springs but actually when you measure them are 8 1/2".
350lb front and 250lb rear give a really well balanced car.
Andyh
Old 15th August 2010, 09:53 AM
aerosam's Avatar
aerosam aerosam is offline
No need no need don't go to those lengths for me! Thanks for the offer though.
My rear springs are vertical as I'm using the BMW semi trailing arms rather than the roadster IRS or locost live axle. (I just wanted to be different!)
I have a fair bit of unsprung weight there, more than a roadster anyway, does that also affect spring rate?
Old 15th August 2010, 10:25 AM
It wouldn,t have been a problem, as I,m taking my suspension off today to fit a side panel, but Spud has given the length info now so no worries.
I don,t know enough about suspension setup to give the info you need
Old 15th August 2010, 11:34 AM
Type in "spring rate spreadsheet" in a search on web and it brings up loads of info.
