Old 12th September 2010, 05:45 PM
Default Applying sikaflex/equivilent.
Any tips on applying the bonding compound?
Did one trans panel today and the stuff was a real pain to get out the caulking tube. Had to use two hands and lots of pressure..
Old 12th September 2010, 05:55 PM
Hi Rob
It is not normally too difficult to squeeze out of the tube,
Can be a bit of a task if you cut too small a bead on the nozzle or have not pierced the top large enough
The usual cosistency is not a lot thicker than silicone sealant, may be well worth checking that you have not got a small blockage somewhere ?
There could be an outside chance that you have been sold some really old stock, it will start to set in a sealed tube over a long period of time
I hope you get it sorted mate .... Nice to see you making progress
Old 12th September 2010, 06:06 PM
hmm, must be as it was cheep off ebay and not the real stuff.
Old 12th September 2010, 06:14 PM
Had exactly the same problem, bought some tigerseal from the local motor factors, and it was tone better!
Adrian
Old 12th September 2010, 06:17 PM
Sounds likely as I use this stuff daily and have no problem,in the depths of winter maybe as it is usually 2 to 3 degrees colder inside than outside.
Tigerseal is the cheaper alternative to Sikaflex and a thin bead will do the trick,clutch and brake cleaner will remove it from your hands etc.
Old 12th September 2010, 08:14 PM
put it in the oven for 5 mins at 200deg that will make it come out nicely. well it worked for me.
Old 12th September 2010, 08:24 PM
Cheers Ash, I will give that a go.
I have also purchased an air caulker.
I had to keep reminding the lad to keep clear of the stick gunk. I think the panel is on for good
