Old 27th October 2010, 08:07 PM
rapidtornado's Avatar
Running on a DOHC with Power steering removed I used this belt.:-
http://www.camskill.co.uk/products.php?mode=search
hope this link works if not go to camskill website and search for 6PK1285
I think the part number system is fairly self explanitory in that 1285 is the mm dimension
In hindsight I should removed the belt tensioner as well as it's not really doing anything for me with the belt setup as it is but hey ho I'll find another belt when I get 5 mins
Rapidtornado
Old 27th October 2010, 08:31 PM
Andy_B Andy_B is offline
cheers ...so its a tight enough fit without ?? more weight to loose
Old 27th October 2010, 10:20 PM
not sure probably have to make an adjustable bracket on top of alternator so there is some kind of belt tensioner, I'll let you know how I get on
Old 28th October 2010, 05:27 PM
Enoch Enoch is offline
Andy B, I can't remember the belt size off the top of my head, I just measured it, went to Halfords and bought one as I did not have one the correct size in my stash. My engine sits about 30mm below the chassis rails at the lowest point, it needs a fairly significant bulge in the bonnet to clear the cam covers, lifting eye and fuel pressure regulator.
Enoch
Old 28th October 2010, 05:42 PM
I am fairly certain there is a stock DOHC setup without the tensioner.
Old 28th October 2010, 05:44 PM
drury318 drury318 is offline
I think if you look for a DOHC carb setup they had a manually adjustable fan belt I seem to recall?
Old 29th October 2010, 12:50 PM
axle's Avatar
axle axle is offline
Hi
I just made the bracket for the alternator, did away with the power steering. Then used a piece of string as the measurement of the belt, took this along to the local Uni-part and got a size under and over. one of them fitted fine and rest were returned for a refund!
Hope this is of some help
Regards Axle
Old 30th October 2010, 06:31 PM
have you got any drawings/dims for the bracket as it will be different to the book right?
