Old 2nd October 2010, 05:05 PM
As far as I know
85GG BC relates to a 3.62:1 dif ratio , Commonly fitted accross the Sierra range.
Old 3rd October 2010, 09:53 AM
tex tex is offline
3.62 diff. Which is a mid range ratio and most sierras used. Should be good to use
Old 3rd October 2010, 12:44 PM
Question Why the double posting
This was answered yesterday when you posted it
Here
I don't think you will get a different answer by asking the same question elsewhere on the forum.
If you have major concerns about your diff a little more background info would be helpfull
As it stands You appear to have a 7" sierra diff that has a ratio of 3.62-1 & is fine for the Roadster
Last edited by AshG : 3rd October 2010 at 01:25 PM. Reason: Moved due to duplication
Old 3rd October 2010, 01:33 PM
I have merged all three threads into one as this topic is starting to get messy.
Ash
Old 5th October 2010, 10:58 AM
Hoybi's Avatar
Hoybi Hoybi is offline
Default differential : best explanation ever
I just found this on the "wide world winternet"
For those who still wonder how it works. They'll never have to ask again.
http://www.autojunk.nl/2010/10/hoe-w...-differentieel
Hope this link works. ;-)
Eddy
www.alfaprojects.be
Old 5th October 2010, 01:11 PM
That explains the Differential Drive which is one component of the final drive unit. the other is the Crown and Pinion gears that Provide the Drive ratio.
Old 5th October 2010, 01:27 PM
Cool Well done Eddy
That is a fantastic bit of information
This film was made in an erra when information was given to you without blinding you with science
Should be mandatory viewing for youngsters at school
Old 5th October 2010, 06:50 PM
misty misty is offline
Tha is real good now anyone can understand
many thanks to all
Old 2nd December 2010, 12:48 PM
seventhheaven seventhheaven is offline
Default Sierra Diff
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at www.super7thheaven.co.uk
Hope that helps - It's a work in progress
