Old 14th October 2010, 07:33 PM
You love a challenge ! Nice one
Old 14th October 2010, 07:39 PM
Looking good, front wheel alignment looks a smidge out though
Old 14th October 2010, 10:07 PM
Tatey's Avatar
Tatey Tatey is offline
It's looking good Andy! Looks much different to when I saw it on Sat.
A quick question with regards to the rear wishbones as I am currently welding my suspension brackets into place.
On page 73 of the book it mentions that the cross brace of the lower rear wishbone should point from the outside rear to the inside front on either side of the car. I was looking at your pictures for inspiration as to what this should look like. And from my interpretation it looks as if your wishbones are on upside down? Please correct me if I am wrong, as I am trying to get it clear in my mind while I go about putting everything together.
Old 14th October 2010, 10:15 PM
Tatey's Avatar
Right ive managed to confuse myself even more. My engineering sense tells me that the wishbones should be installed the way you have them as the force will mainly be acting to push the wheels rearwards, this agrees with the cad model in the front of the book.
However the picture on page 74 makes things even more confusing as it is the other way (the way I've interpreted the description).
Old 14th October 2010, 10:30 PM
Ahhh the rear wishbone debate....
I think the book corrections section has that in it.
Old 15th October 2010, 10:01 AM
I have taken the same approach and thoughts as yourself Tatey, the forces on the wheel traveling forward are transmitted from the front outer of the diagonal to the rear inward for the lower suspension arm. Seems to work fine for me.
Hope that makes sense......AndyH
Old 15th October 2010, 10:23 AM
I have seen them cross braced.
