Old 20th October 2010, 06:02 PM
Never had bother with prop bolts. If the shells a scrapper then I cut a hole in the floor so I can see it from the top
Old 20th October 2010, 06:13 PM
Andy_B Andy_B is offline
Was thinking about that too !! just the risk of setting it on fire before i am finished with it !!...set my jumper on fire today with the big 9" boy !! only other prob is the bloody gearstick willnot come of the union (mt75) got the pin out but its no budging !!
Old 20th October 2010, 06:29 PM
Hammer and chissle will do the floor nicely.
Never split the leaver of an MT75, Just drop the box myself.
Old 20th October 2010, 06:45 PM
Think i have a hand held nibbler...not much patients for stubborn shit so the sds and chissle attachment might come out tomorrow !!
Old 20th October 2010, 06:56 PM
Hand nibbler will take 10 times longer than the hammer and chissel
Old 20th October 2010, 07:33 PM
You may have a point there ..ok lump hammer and chissel ..as soon as i get the kidds of to school in the morning !! thanks for advice by the way
Old 20th October 2010, 08:31 PM
I do the same above the driveshafts too to undoo them from the diff
Old 20th October 2010, 09:00 PM
So you cut a hole in the arse of the boot ?? it need drained anyway full of bloody water !!
Old 21st October 2010, 06:30 PM
Right thats the engine out...nut splitter and a good impact gun did the trick...bust the nut splitter on the last nut so its back to screwfix for sa replacement...forgetting to mention the use of buzz gun !!!.....ANOTHER question....how much of the loom do i carefully remove ? i have the ECU out but by god do i have more other parts of the loom ie ABS (not needed) Bulb failure unit ...wondering if the whole lighting loom goes through that....any assistance regarding 2.0 DOHC loom would be very much appreciated....
Old 21st October 2010, 08:47 PM
I would junk everything apart from the engine loom. there's an excelent wiring diagram thread for a simple loom that will cover all you need.
The donor loom ( in my opinion having owned, stripped, fixed rebuilt countless sierras + granada and scorpio ) would take more time and effort than building a new custom loom.
