Old 24th October 2010, 09:24 PM
squbti's Avatar
squbti squbti is offline
It´s just that I have the first of 3 tests on the car comming up in one week & I need to sort out theses problems before that if I can I´m trying to keep it as low as posible but I´d like to have some good clearance at the same time .
has anyone needed to have spacers under the motor mounts? Is that something i should try? The way I see it even if I had 100mm in the front i would still have 65-70mm under the sump & gearbox
Thanks
Samy
Old 24th October 2010, 09:29 PM
Try raising it Samy, Do you have speed bumps where you are (traffic calming).
Old 24th October 2010, 09:40 PM
squbti's Avatar
I´ll give it a go tomorrow, we dont have any speed bumps here or not alot anyway but we do have alot of roundabouts & also people can get perments to put out flower beds/boxes in the street to slow down trafic most of the time drivers go faster because they think its fun to zigzag between the boxes, so that shouldnt be a problem with the sump anyway.
Samy
Old 24th October 2010, 10:20 PM
Sounds like fun,good luck.
