Old 21st January 2011, 08:50 PM
rich's Avatar
rich rich is offline
Originally Posted by rich View Post
no, rear but will need to extend the track rods
lol i think in the photo hes using a o/s hub, when the photo was taken it was just initial mock up i think they have changed the set up since then.
Old 21st January 2011, 08:55 PM
mk III astra bottom ball joints
Who spec'd them.
The don't take load the same way as the maxi.
Old 21st January 2011, 09:03 PM
rich's Avatar
Who spec'd them.
TT[/quote]
they did, im not clued up about that sort of thing, i dont know how different the loading would be having the shocks mounted inboard
Old 21st January 2011, 09:11 PM
if the suspension load is transfered from the lower wishbone then the load on the joint will be different to the original design load.
If the suspension load goes through the topmount then the lower will be ok , but the top may be overloaded.
3GE built an inboard chassis.
Old 21st January 2011, 09:20 PM
rich's Avatar
ahh i see, i think they also fit them ball joints to the cavalier and calibra.
They do seem to know their onions
Old 21st January 2011, 09:29 PM
Do the onions go with the "Mushrooms" ? sorry couldn,t resist
Sounds like an interesting build you got there Rich
Look forward to seeing some build photos
Old 21st January 2011, 09:32 PM
Almost certainly do, Astra, cavy and calibra all load suspension weight through a Mcpherson strut on the top of the suspension upright. this leaves the bottom joint mainly doing location work only.
The maxi balljoint is larger and on the original car took the suspension load.
The astra joint may last or it may not.
Many years ago ( back in the 80's / 90's ) a fair number of 747's lost their engines (literally). Mainly Pratt & Whitney ones not RR ones. The conclusion was that the bolts holding the engines to the airframe were perfectly up to the task of taking the thrust during flight. But the reverse thrust during landing caused stress on the bolts eventually leading to them shearing and the engine falling off.
Old 21st January 2011, 09:38 PM
rich's Avatar
lol leave it to the experts, Im going to be learning all the time with this, electrics i can do chassis design is a bit beyond me.
Old 21st January 2011, 09:47 PM
Vauxhall keep doing that, and their chassis guys still build chassis that handle appallingly.
I preferred the handling on the MK3 Rasta van over the MK1 Vectra (I class that as the one of the worst handling cars I have ever driven).
Old 21st January 2011, 09:53 PM
rich's Avatar
could be worse, they could have had escort lower arms
