I take it the rear tub lower lip goes under the rear rail and not over it.
That is what I assumed from handyandys post in the side panel thread.
Have you put your sides on yet tt?? I'm about to do the nose but worried it's not looking right. |
No, not yet. I was just playing whilst I had 5 mins.
I need to finish off the engine mounts (ran out of gas on thursday) and then pull the engine and crack on with the fitting up. TT
Rear grp tub does indeed sit underneath the lower rails, you can then either rivet it on or use rivnuts. I would use rivnuts and 6mm dome headed allen bolts as it lets you take it off a lot easier at a later date if you have to.
I was indeed going to use 6mm dome's and rivnuts on most panels.
I was planning on using normal Sillycone Sealer in-between to keep moisture out of the gap ( comments? ). TT
Silicone will be ok, only use something stronger if you don't intend taking the panels off. I once used sikaflex to put some side panels on then changed my mind on colour.....ummmmm I actually broke the side panel trying to get the damn thing off so be warned peeps sikaflex is damn strong sticky stuff
).My rear tub is rivnutted to the chassis & the wings bolted to the rear tub, so its all easy to remove if need be . cheers andy |
| Thread Tools | |
| Display Modes | |
