Old 6th February 2011, 08:08 PM
David_17's Avatar
David_17 David_17 is offline
thats something I,ll need to address then , as my cut off switch currently kills everything, hadn,t thought about hazards to work without it,
thanks for the reminder
Interesting, can anyone confirm that? As mine's the same as HAndys
*updated 7/6/11*
Old 6th February 2011, 08:40 PM
Yes thats true, you dont need it for iva your steering lock and your key are your two methods of security
You should have fitted the kill switch after iva!
I had one fitted under the dash at my iva but i boxed in under the dash so it couldnt be seen, then i removed the covers after iva so i can shut it off when i like
If you have already done it you could fit a 10amp fuse across the shut off switch, this would let your hazards etc work but would blow if someone tried to start the car
Old 6th February 2011, 08:55 PM
David_17's Avatar
Do you mean just put an inline fuse between the 2 contacts of the switch?
*updated 7/6/11*
Old 6th February 2011, 09:21 PM
Yes as that would let your hazards work even with the isolator off
Not sure what mr iva would have to say if he saw it though, if its not too much trouble just remove it until afterwards
Old 7th February 2011, 11:20 PM
just conect both cables on just one of the studs for iva then its on all the time then put it back after simples
