Old 12th August 2012, 06:18 PM
gaz05 gaz05 is offline
Originally Posted by alga View Post
* The radiator fan control signal is grounded for off, disconnected from ground for on. So, another MOSFET is needed to drive the fan relay, or a normally closed relay. Or an original transistor fan relay out of a Mondeo.
There's two relays on the model with air con. One is switched on pin 31 and the other on pin 13. Do you know if it's possible to use pin 31 to switch a normal relay or is it be possible to use a five pin relay adapted to use the normally closed contacts and switched by pin 13? I'm adapting a Daiwoo Matiz fusebox with escort dash,sierra switchgear and Mondeo ECU.
Total cost so far
Materials £3,150
Tools £855
Old 24th August 2012, 06:01 PM
big_wasa's Avatar
big_wasa big_wasa is offline
No it wont work. The ecu uses the fan to draw the warm air for the gas conversion for the Ac to work. It relys on the pressure switches aswell.
Nowt again.
