Old 4th April 2011, 07:03 PM
Peter-C Peter-C is offline
Default Horny question 2
Thanks for that but I now have another horny question !!
The switch inside the steering wheel is for a switched earth which the donor does by relays or the alarm unit. I didn't intend to use a relay, but both of the horns have the body connected to earth. Can I use the horn push as a switched live or is this dangerous ?
Hope someone understands.
Pete
Old 4th April 2011, 07:29 PM
Hi Peter
Adrian is bang on there
If the horns are earthed at the body ( Only have a single pin for the live )
Use the horn push wire to switch a realy as sugested.
Not a great idea to use a live wire for the horn push
I am sure some bright bod will knock you up a quick diagram if you shoud run into any problems
Old 4th April 2011, 07:33 PM
Cheers Adrian
PM sent.
