Old 9th May 2011, 07:53 PM
jerkins's Avatar
jerkins jerkins is offline
Originally Posted by leroybrown911 View Post
Aircraft actually take more of a hammering than a road car, its the buid philosiphy that makes it work.
I doubt whether an aircraft would hit as many potholes though...
Old 9th May 2011, 08:06 PM
Suprisingly strong for the hammer they take considering the dimensions of the parts they are fitted to and the size of the fixings they use.
Personal experience of clattering onto a runway at 80 knots with all three wheels at once and near flattening the oleo's
Saw the rotor head removed from local plod helicopter and it was with a few "Jesus" bolts,youv'e guessed it. Jesus, is that all that holds that on !
Old 9th May 2011, 09:28 PM
Originally Posted by KAMBO View Post
how much less would a chassis weigh if built in 2mm wall ali box section ?
On Page 53 of the second edition of Ron Champion's Locost book, he is shown holding an aluminum chassis up in the air. He wants us to think he is very strong, so he doesn't admit he is cheating.
Old 9th May 2011, 09:51 PM
jerkins's Avatar
My brother is currently building an all-aluminium light aircraft (a Van's RV-4) - it's scary to see how flimsy each component is, and amazing to see how rigid the parts become when riveted together. Each fuselage & wing part is made of 1.0 - 1.5mm sheet aluminium alloy.
He will end up with a 200mph 2-seater aircraft that weighs over 200kg less than my Locost...
Old 9th May 2011, 09:52 PM
Some ruskie pilot landed one of our corporate jets with the tail a bit close to the runway and scraped the tail end. Its now being braced up and brought back to the uk for us to fit new skins, keel section of engine beam frame and then back into the air.
Old 10th May 2011, 07:07 AM
snapper snapper is offline
Another problem to be aware off is the wishbone bush bolts going through aluminium brackets, or steel tube and aluminium together causing different metal electrolysis.
The Robin Hood lightweight was an ally monocoque designed as a one season race car, it needed a Hugh amount of re-engineering just to be strong enough to pass IVA.
A well designed steel chassis built with the lightest bits can be around 400Kg
