Old 9th June 2011, 06:41 PM
Originally Posted by steve8274 View Post
where are the pre shortened sumps available from?
i am after one for a cvh but unable to weld so cant do my own
thanks
steve
There are some here Steve:
http://www.dunnellengines.com/zetec_...partno=RMP1400
http://www.scholarengines.co.uk/Lowline%20sump.htm
Not cheap but they are good, sometimes you'll find them on e-bay. The bolt patterns are the same as CVH but the end corner, 6mm, holes are missing on the Zetec but if you use a new gasket and sealant it will be fine.
Andrew
Old 10th June 2011, 12:47 PM
brainbug007's Avatar
I'm going to give cutting mine a go, only bit that worries me really is shortening the pickup pipe and I can imagine getting that sealed with weld properly so it isn't overwelded and not enough oil gets up the pipe or underwelding and it leaks :S
Old 11th June 2011, 09:46 AM
MarkB MarkB is offline
See if you can find a local firm who can tig weld the tube for you.
