Thought I'd start a new thread on this.
I was hoping this would be a quick job as it looked really straight forward, after some cursing I can't work out quite how to fit this. If I had a rear tub it would be easy! I got the GRP parts from Handy as part of his kit. GRP2 as shown in the photo has a 5 deg end and a 90 deg end. From the pdf for the rear panel it looks like they should both be 90. So should they be straight cut if not which way round does this peice go? The modified 19mm diaganol tube (that links the GRP rear to the diff carrier framework) doesn't seem to line up either. Is the position of the flat plate that the tank sit on correct? Has anyone got the height off the build table for the rear most 25mm tube , if i have this I can weld up and make the diaganol to suit. ![]() IMAG0213 by mjb22001, on Flickr ![]() IMAG0211 by mjb22001, on Flickr
Build Cost so far £xxx (Given up adding it up) - She Starts!! Build Thread Here: http://www.haynes.co.uk/forums/showthread.php?t=5501 Last edited by MikeB : 11th May 2011 at 01:28 PM. |
| Thread Tools | |
| Display Modes | |
