Old 3rd February 2012, 04:41 PM
Default Megasquirt help required - trying to go for first start with Zetec
Hi there, looking for some advice / help starting my zetec for the first time. It's a 2l Silvertop with 40mm Jenveys, and an MS2 V3. Wired it all up, set the req fuel, set up the TPS, calibrated the sensors and checked the wiring. Got a base map from Phil at extra efi for a zetec with throttle bodies. all good so far, just turn the key and go! Err, no actually, turn the key and cough cough, wants to catch by the sound of it, but no joy. Turned prime pulsing off to make sure I don't flood the engine, and tried several times, but no joy. If it helps, it seemed to want to start more when I used a little bit of throttle.
Any help or advice as to where to start fault finding would be great.
Adrian
My Build Pictures:
http://s1234.photobucket.com/albums/ff406/adrianreeve/
