Old 15th March 2012, 12:34 PM
cirrusjock cirrusjock is offline
Default cutting steel - accuracy
Hi
Another stupid question, I am cutting my steel using an angle grinder and cutting disk. Some of the angles have come out slightly uneven. This means when you put it against the next section there are small gaps. Particularly the 74 degree engine supports. I know these will be filled in when it is welded but will this be ok or should I redo it.
I am teaching myself to weld and getting there but am worried about the strength of the finished chassis. I have visions of it coming apart on the road
