Old 19th March 2012, 08:49 PM
Eternal Eternal is offline
Default Urgent cage advice needed :D
Right the cage has arrived and i have noticed that the top of the rear hoop has an angle but the front hoop only has a 25' rake backwards but no inwards bend.
I cant decide what to do. Get the back hoop remade so its straight up or... have the front hoop remade so it bends backwards 25' and inwards the same as the rear. Will need to let the chap know asap to be able to place an order and recieve it by friday.
Skyline Roadster
Old 19th March 2012, 08:50 PM
Ops double post
Skyline Roadster
Old 19th March 2012, 08:56 PM
Hi Alex,
My opinion rake it inwards to suit rear hoop..
Old 19th March 2012, 09:17 PM
I looks fine, use it as it is. When all the other tubes and the windscreen are in place and you step back from it, it will look like you designed it to be that way.
Old 20th March 2012, 09:29 AM
I did not really notice it untill it put the crossbars in place then it makes it more noticeable as you can see the distance between bends is different.
Will be running an aero screen to keep things simple for IVA. I'm really not sure what to do.
The easy and cheap option is a new straight up rear hoop but it wont look as funky. But the proper option would be the front hoop. Bugger!
But have to admit the service from Scorpion has been fantastic and they have done everything exactly as asked. Its my fault for dodgy specification heh
Skyline Roadster
Old 20th March 2012, 10:55 AM
MikeB MikeB is offline
bend the front in will look best.
Personally hate bad looking cages so spend the cash and get it right as you'll always think it could have looked better!
Old 20th March 2012, 03:02 PM
if you change the rear hoop someone here will want the old one I bet.
