Old 16th May 2012, 07:41 PM
That certainly sounds like a problem that needs addressing.
Old 16th May 2012, 07:49 PM
rpjg1975 rpjg1975 is offline
Also the black and yellow wire at the back of fuse 22 has been snipped. When I connect up the 2 I get all three lighting up
Presumably this is problem solved?
Old 16th May 2012, 09:15 PM
fuse 22 supplys various circuits. but none of them will be much of a worry
(door ajar warning, ventilation, wiper, abs )
So splicing in a new wire should do you.
Old 16th May 2012, 09:29 PM
Excellent news, that possibly explains why I chopped it out in the first place, worked out I didn't need it. How wrong could I have been? As it is I am only using the standard clocks unilateral get my new clocks and gauges fitted in the dashboard i am making. Hopefully wiring them up should be relatively straight forward once I know what wires do what in he back of than standard clocks.
Many thanks for all the help, dunno what I would do without this forum and its members sometimes
Russ
Old 16th May 2012, 09:33 PM
It's a massive help having correct ford original diagrams.
Glad to be of help.
