Thanks for all the replys.
My Blog: deannoshaynesroadster.wordpress.com (under construction) Being overtaken is a sign of weakness. South Wales Kit Car Club www.southwaleskitcarclub.co.uk WWW.HELPFORHEROES.ORG.UK XBox Gamer tag: D34NNO |
this effects the engine or its idenity in no way and it can be reused and its no. is used only to track its origin, parts build and idenity etc. if that helps any |
And you will get an age related number.
If you get a car with a nice number then it needs to be transfered on to retention ( needs to be within 1 year after expiry of last MOT). You scrap the donor with it's DVLA crappy reg. You register the Kit Car using the old V5 as proof of age of the donor parts. You get an age related plate. You transfer back on the nice number.... TT
Its all done on a tot up of points, retain eight points on the score card and no q plate is needed. If the engine you want to use is added to the log book prior to the application its worth an extra point. Its all in the bit below.
http://www.direct.gov.uk/en/Motoring...icle/DG_191068 Bob
When The Results Disagree With The Theory: Believe The Results And Invent A New Theory If I had two brains I,d still be a halfwit The cave http://s1116.photobucket.com/user/my...deshow/mancave The build http://www.haynes.co.uk/forums/showthread.php?t=12669 Last edited by robo : 20th May 2012 at 05:45 PM. |
| Thread Tools | |
| Display Modes | |
