Old 31st May 2012, 10:45 PM
shh120m's Avatar
shh120m shh120m is offline
Default Right then bits for sale...
As everyone loves a bargain il put what i find in my clearout up here first before it goes on the old ebay. Il update the list as i find stuff and as stuff goes. Because of all the pms at the moment i think its best to keep track of whos buying/bought what on this thread so i dont lose track of things when im deleting pms to keep the inbox free.
So to start with i have 5 bonnets, all seconds but with no damage, they have marks in the gel and bits that need polishing/sanding but as they are sold as seconds you may find the odd bit of damage but they are going for £40 each just incase. postage will be a tenner to cover bubblewrap and a bit of card
Iv got
Bodywork.....
Bonnet dark blue wide scoop SOLD DEANO dispatched
bonnet gulf blue normal scoopSOLD Tatey dispatched
bonnet golden yellow wide scoop SOLD PeteY dispatched
bonnet saturn orange normal scoop SOLD SteveMX5 dispatched
bonnet kawasaki green normal scoop SOLD GAZ05
Also got what look like a set of old cobra moulds, these were a handme down i didnt really want them, but kept them anyway, i have no idea wheat model they were for maybe markb knows. Come and collect for some beer tokens, youll need a big van or trailer
Structural......
EDIT . Just found a brand new nissens Clio radiator. I used one of these on my own build, it fits but its a chore to fit, has to be positioned perfectly to get the nosecone over, £27 quid posted.
Theres a set of sierra front wishbones. Front lowers are seconds, they were spot on lovely when done, but they were mysteriously damaged in transit, one of the shock brackets was bent inwards as if someone had them in a vice, can be straightened or replaced will throw in a new bracket with them. The uppers came off my first build, they are good but i never chamfered the edge of the bush tubes as i didnt have a lathe at the time, just means youve got to be careful when your putting polybushes in. £36 posted
Pair of sierra front uprights, these have never been used for anything but mocking up, been hammerited, were about a hundred quid from rally design. £45posted
Full set of suspension brackets inc shock brackets £30 posted
3 sets of rear upright plates. all plates for rear uprights except for the tube £14 inc postage per set. If your stuck for the large radius tube, if ones careful it can be made out of a single piece of strap approx 400mm long, using the round plate as a jig. SOLD Ronnie
Mazda mx5 1.6 diff, open good working order just needs a clean/polish paint £50 posted due to weight
23 kitcar magazines mix of ckc tkc and kitcar £15 posted
Spare 2ltr zetec head, bare, but with a pair of cams nice and clean been used as a table piece casting number xs7g-6090-ac £30 posted
Sierra 7inch diff pushfit (not sure of ratio cant be bothered looking)
Driveshafts (SOLD)
Front suspension bracket jigs made from 20mm box section steel hollow round tubing and m12 threaded bar. Spot on much better than book spec jigs. £40 posted, buy them use them and sell them on? (youll need some m12 nuts, i cant believe i had hundreds, have a clearout and then i cant find any lol)
