Old 15th June 2012, 12:02 AM
BenBrooks BenBrooks is offline
Cool
cheers handyandy.
i'll upload some pictures soon, i'm afraid progress is slow but the chassis is almost complete! just need to earn enough to get some running gear in time for the summer holidays
Old 15th June 2012, 12:07 AM
Originally Posted by BenBrooks View Post
cheers handyandy.
We all like build photos
Hey...any small progress IS progress, keep at it, we,ve all been at the same point in our builds so know what the build process can be like.
Maybe put your location in your profile...you may have a fellow builder close by to gain / swap build tips & it also helps with motivation when you might need some
Hope you enjoy the forum too.
Old 15th June 2012, 12:31 AM
cheers guys. could sikaflex be used instead of pu? purely because i've already got it sitting in the garage?
Ooo another southerner welcome to the forum. Your not the only person in Guildford, Robo is in worplesdon.
Old 15th June 2012, 06:55 AM
Welcome to the forum!
Most of us seem to use ali floor held on with rivets and sikaflex. I'm sure it's not a problem!
Use sealed rivets and/or put a blob of sikaflex on the end of each rivet to help reduce oxidation.
I seem to recall reading somewhere that some race series require a steel floor though, so bear that in mind if you ever plan to race it.
Old 15th June 2012, 10:14 AM
You could probably dispense with the rivets all together, the sikaflex is very sticky stuff.
Old 15th June 2012, 03:11 PM
Some manufacturers turned to bonding panels of a none structural nature on to cars and what a bugger they are to get off.
Old 15th June 2012, 10:30 PM
ah i'm in worplesdon so he may be hearing from me if i ever get stuck! lucky him!
Old 15th June 2012, 10:35 PM
Wow
I didn,t expect it to be that close
Old 19th June 2012, 12:06 PM
Try a test piece for yourself. scotchbrite and degrease a piece of spare box section and a strip of ali. Glue and rivet a small section and let it cure a couple of days. Then try to get them to part company, if you have done it right the ali will tear before the bond lets go.
bob
Old 19th June 2012, 04:02 PM
Deanno's Avatar
Deanno Deanno is offline
I'm using 2mm steel, as i was able to get 2 off- cuts and weld them together. cheaper than buying ally.
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
