Old 11th August 2012, 02:57 PM
silvertail silvertail is offline
Originally Posted by voucht View Post
I wanted to use the SOHC engine, as after a chat on the forum last year, it looked like the DOHC, because of the EFI, will be too high to fit under the bonnet, even with a scoop like "new" Saturn's bonnets (Spud told me that last year). But when I see both engines, it looks to me like the EFI of the SOHC is even higher over the hear cover than on the DOHC, wich is on the side, and not too much above the head cover level. What do you guys think? On which engine should I work?
Thank you.
I tried to install a SOHC engine with EFI into the Roadster chassis and found it clashed with the wide scoop Saturn bonnet. I had 60mm interference with the engine/gearbox running along the chassis centreline, and ~20mm if they were angled to move the inlet manifold closer to the bonnet bulge.
If it's any help I can email you some photos to show where the clash occurred - you may be able to think of a better solution than mine which was buying bike carbs! Wish I'd known about the Equinox option back then
Mike
